1 - 20 of 83 Posts
Hey Maynes,
I've been running Amsoil 10W40 for the last 3 oil changes (so approx 9k miles) but was thinking of switching over to Motul 300V (the green ecto-cooler looking oil)
My question is this: As I will obviously not be able to FULLY drain all of the 3.3Qts of Amsoil that is in the case, will it be ok to have some slight mix-age going on? I am not sure how similar or different the oil profiles are between the Amsoil and Motul 300v, but they are obviously totally different colors etc so more than anything I just want to make sure that the first few changes aren't harmful in any way seeing that I'll have a bit of old Amsoil (that I couldn't get out with the drain) in the new fresh Motul 300v! Anything to worry about? *
Official Noob Greeter
It'll explode, better just give the bike to me.....
Was it as good for you?
The biggest concern with using different oils is mixing weights more so than different brands. As long as you are using the same weight oil (ie. 10w-30 amsoil and 10w-30 motul) you shouldn't have a problem.
Sent from Motorcycle.com App
Stunt Rider
I hear olive oil will help stabilize the two oils together.
I like corners.
There's not a single problem with mixing oil weights. Stop spreading misinformation.
Reads the rulez
Who told you that retarded information?
Everything with an engine takes a specific weight oil correct? Depending on climate and engine type different weight oils are required. I'm not saying it won't run, or blow up, but it won't be the optimum mix for the application. Mixing 10w-30 and 15w-45 would come out to a weird ratio.
If it doesn't matter what weight oil you use then why are there so many different types....
Make good choices.
Hey Maynes,
Take the motor apart and scrub out the galleys with pipe cleaner and toothbrush.
Just like Die Hard with a Vengence when they had those bombs that explode after the two liquids mix together. That's what happens when Motul and Amsoil touch each other.
I like corners.
No. Multiple different oil weights can be used on the same engine with the same results.
You're contradicting your first statement. A vehicle can be subjected to a different climate within the same period between oil changes, and still be just fine.
Why is that? What you listed could be 100% acceptable for a vehicle. As long as the cold and hot oil weights of both oils were within the limits for the engine and its use, there would be no issues from mixing the 2.
Where did somebody say oil weight doesn't matter?
:popcorn:
Yeah Science!
You have to clean the inside of the engine with unicorn semen
Then why do manufacturers specify a specific weight for vehicles?
Well is the same true for prolonged periods of time? I mean you wouldn't put a heavy weight oil in if you lived in a super cold climate, at least I would hope not.
As you said, It "could be" acceptable. I don't know if it is or not. Do you? And what would be the proper way of finding that out. It seems there would be too many unknown variables, internal engine defects for example.
That was more of an open ended question than a statement. But it seems everyone is defending the fact you can mix, match and use non specific weights without concern. It seems as though that is being inferred without saying that exactly.
I like corners.
Many manufactures list multiple different oil weights you can use depending on your climate.. To say that an engine can only run one specific oil weight is crazy talk.
Are you ready to have your mind blown? Are you???
Get ready......
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_0W-40.aspx
Technology..... :dizzy
Could was referencing, "As long as the cold and hot oil weights of both oils were within the limits for the engine and its use". There are no unknown variables. Do some research as there is an endless amount of info on this around the internet. just because 'you' don't know, doesn't mean that it is an unknown...
It's because you can, and TBH you're the only (ignorant) one in here saying that you can't...
See in blue.
Well OP just go ahead and throw whatever in there. Maybe some 30wt oil, if you have a quart lying.
Also someone should call some of the major oil companies and inform them they are wasting millions on R&D. That oil is oil.
Reads the rulez
Do everyone a favor, mainly yourself, and quit using the internet.
Reads the rulez
Partially correct
Also partially correct
You guys almost had it.
You have to take the motor apart and scrub it with a pipe cleaner and toothbrush. That are soaked in unicorn semen.
And the Die Hard reference made me laugh very hard at the computer and my dog can't figure out why I randomly bursted out in laughter. :lmao:lmao:lmao
1 - 20 of 83 Posts
