Hello! I’m having issues with my 2009 R6, it turned on like usual today, after 5 minutes of being on I hit the kill switch, and I didn’t turn off the ignition, let it sit for about 10 minutes, went to start it but it just clicks, it goes for about 2 clicks trying to start then gets slower and weaker, while trying to start the dash completely turns off, I let go of the start button, and it resets like I just turned the key. Haven’t done any work to the bike in a few days but everything’s been working, I don’t let it sit for more than a day usually. Reading between the positive and negative points on the battery says 12.4V. Even heard a buzzing sound from the back when trying to start once.
YZFR6... ooodles of HP
Starter relay and ot battery voltage drops during crank because it's done.
you killed the battery. if you have done this more than 2 or 3 times it's probably going to need replaced. they don't like to be discharged like that too many times. do yourself a favor and shell out the money for a AGM GS battery. it's a subsidiary of Yuasa. only use a tender periodically not all the time. it will last 10 years. yamaha uses their high performance AGM battery stock. Motorcycle and Powersports Batteries Archives - GS
Discussion Starter #4
If this helps here’s a video of it, the shocking sound just happened for that first time
Yep that battery is toast.
  • Like
Reactions: yamahacrazy
Discussion Starter #6
Alright, taking it to autozone to check it, n see what they got, I’m looking for what’ll get it running again for now, then soon I’ll get a better model, any highly available recommendations?
