1 - 3 of 3 Posts
Been having issues with my TPS, error code 59 was thrown, the diagnostic numbers made no sense and my throttle was unresponsive. I finally took apart my bike to find out a rodent had been living in between my radiator and engine block and actually chewed through the wire insulation as well as the blue wire for my TPS. Looking online i'm only seeing full bike wiring harnesses or individual TPS sensors without the wiring. Does anyone know where I should begin looking to find just the plug/wiring harness for my TPS without having to buy the full thing(if it comes down to that I will, but if i can save a couple bucks not replacing the working sensor then i'd prefer that.)
If you handy with a soldering iron, it might be an easy fix. Remove the harness, pull all the tape off and have a look.
^ yeah and while you're at it, maybe you can find that rodent and use the soldering iron to give'em a tattoo that reads, "STAY OFF MY BIKE!!!" ;)
1 - 3 of 3 Posts
