1 - 2 of 2 Posts
You should be able to just reconnect those wires to the switch, without any problems. I would split that brown connector to get some extra slack. And as for the power commander, (I'm sure that I will be corrected if I am wrong) but I believe that the pcv is a piggy back system. So with Not having it, the bike should run, only using the factory/ default mapping. And looking under the seat.... the only thing that I see is that your batteries neutral or ground terminal isn't hooked up
1 - 2 of 2 Posts
