HI, my bike hasn't been starting for a while and i got a code 11 which is the camshaft positioning sensor. I ordered a new one hoping that it will fix the problem. Although, i checked the voltage at the coil's wire harness and it only reads 9 volts. When i crank the engine it can go all the way up to 15 volts. The battery is new and it reads above 12 volts so shouldn't the wire harness read the same voltage?
i checked all the grounds and it seems fine; continuity on all the wires are ok too.
