1 - 2 of 2 Posts
I noticed my clutch was slipping when in high rpms and right after shifting during a pull. I bought a clutch rebuild kit and put new pressure and friction plates in aswell as new springs and a gasket. After the install I noticed my clutch lever was stiffer than normal but I figure its because of the new springs. I turn it on and pull the clutch and it goes into first but when I let go of the clutch nothing happens. When I take the oil plug out I can see that when I pull the clutch in the plates move a little bit but not a lot. I don't know how much they are really supposed to move though. I also adjusted the clutch cable on both ends. Any input helps a lot and I would greatly appreciate it. If you need any other information to help get an idea just let me know. Thank you.
1 - 2 of 2 Posts
