Solved:
Cluster came in ended up being code 19, found a damaged wire on the ignition switch under the wire wrap stuff, would then start but die in gear quite a bit of researching and trying this and that led me to the starting cut off relay under the gas tank swapped it out from a running r6 and went right into gear! Rebuild looking promising.
