1 - 20 of 49 Posts
Alright I've had enough with this stuff in my garage. After a few weeks of parting out my 2006 R6 here is what I have left. Everything is MAKE AN OFFER. The more you buy the bigger discount I will give! I simply ask that you pay for shipping. I will also throw a few random bolts, tubes, etc in the box from stuff I have sitting around from the part out that is too meaningless to sell separately. If you dont want it you can throw it away. Thanks!
1) Frame w/no title
2) Sprockets - 17, 46, 46 (used), 48 (used), 49 (used), 49, 50, 51
Used have been used for 1-2 trackdays at most. 48 and 49 used come
with sprocket carriers!
3) Rear Brake Rotor
4) Original Throttle w/cables
5) Main Wiring Harness (Nothing cut)
6) 4x Ignition Coils
7) Fuel Pumps x2
8) Battery Tray
9) Frame Sliders (1 brand new complete Graves set, 1 extra set of sliders with it and a bunch of brand new Vortex frame sliders made for the R6 as well) I want to sell them all together
10) New, never mounted upper triple tree
11) Upper triple w/ignition and key
12) Clutch Cable
13) Rear Axle Chain adjuster thingies x2 sets
14) Front and Rear Axles
15) 1 Clip-on (with some holes drilled) and grip
16) Puig DB Screen
17) Heat Protector/shield
18) New GYTR Air Filter
19) 1 extra sprocket carrier
20) Rectifier/Regulator
21) Levers (2x brake, 1xclutch)
22) EXUP Servo Motor w/bracket
23) Bar Ends x5 sets
24) Lower Triple Tree w/bearings
25) Chain Guard
26) Kill Switch
27) Coolant Reservoir
28) Front Calipers w/SBS Dual Carbon Brakes
29) Rear Caliper
30) Throttle Bodies and Secondary Injector Rail
31) Complete Sharkskinz SB Bodywork w/windscreen and new frame sliders (bodywork on bike can be seen in pics below)
32) 2 extra Sharkskinz SB lowers
33) 1 Blue OEM Tank Shroud
34) 1 damaged (but repairable) Sharkskinz Tail w/underdraft
35) ECU
Mario J's Apple Juice
Not sure but I think the mods might ask you to post prices on your items. Also helps us buyers by giving us a general idea of how much you want for the item and not to offend you or anyone.
Fair enough....
1) Frame w/no title .... $250
with sprocket carriers! ....$35 each
3) Rear Brake Rotor.....$50
4) Original Throttle w/cables......$50
5) Main Wiring Harness (Nothing cut).....$80
6) 4x Ignition Coils.....$70
7) Fuel Pumps x2.....$35
8) Battery Tray......$30
9) Frame Sliders (1 brand new complete Graves set, 1 extra set of sliders with it and a bunch of brand new Vortex frame sliders made for the R6 as well) I want to sell them all together.....$85
10) New, never mounted upper triple tree......$40
11) Upper triple w/ignition and key.....$50
12) Clutch Cable....$5
13) Rear Axle Chain adjuster thingies x2 sets......$25
14) Front and Rear Axles.....$15
15) 1 Clip-on (with some holes drilled) and grip....$5
16) Puig DB Screen.....$35
17) Heat Protector/shield.....$25
18) New GYTR Air Filter.....$65
19) 1 extra sprocket carrier.......$20
20) Rectifier/Regulator.......$25
21) Levers (2x brake, 1xclutch).....$20
22) EXUP Servo Motor w/bracket.......$50
23) Bar Ends x5 sets.....$30 for all
24) Lower Triple Tree w/bearings.....$50
25) Chain Guard.....$10
26) Kill Switch.....$25
27) Coolant Reservoir....$20
28) Front Calipers w/SBS Dual Carbon Brakes......$100
29) Rear Caliper......$50
30) Throttle Bodies and Secondary Injector Rail......$125
31) Complete Sharkskinz SB Bodywork w/windscreen and new frame sliders (bodywork on bike can be seen in pics below).....$400
32) 2 extra Sharkskinz SB lowers.....$75 each
33) 1 Blue OEM Tank Shroud.....$45
34) 1 damaged (but repairable) Sharkskinz Tail w/underdraft.....$45
35) ECU......$75
Pics of the upper tripple tree and frame sliders? PM me.
Just Burnin Time
Ill take the screen if its still available. Send me your paypal.
Discussion Starter · #18 ·
Headin out the door for a week on my honeymoon. Sorry but I wont have internet for a week. I'll get back to everyone when I get back. Everyone who got stuff...if you paid me by yesterday it was shipped out today. Thanks!
Discussion Starter · #19 ·
Bump. Back from the hmoon. I think i responded to everybody. Let me know if I missed anyone. Really would like this stuff gone! Thanks
1 - 20 of 49 Posts
