1 - 2 of 2 Posts
Hi.
Im having an annoying issue with my R6.
Bike has 32000km full two brothers exhaust and a power commander V.
When i start the bike its fine. But when i leave it on idle after 1 minute it will die if i dont hold the throttle a bit. and if i start the bike and im not idling that problem wont happen. then when the bike is hot it will idle no problem. its seems to happen just when the bike is cold or warming up.
Im still running the stock air filter could this be an issue ?
anyways let me know what you think it could be. thanks
Sent from my SM-N975W using Tapatalk
Fat + S = Fast
Unplug the PCV and see if the problem goes away. If it does plug it back in and load a zero map. If you still don't have a problem, then your map was doing it. If you do have a problem with the zero map, your PCV is borked. If you unplug it and nothing changes, it's probably a maintenance/tune-up issue.
1 - 2 of 2 Posts
