1 - 8 of 8 Posts
Anyone that has a 2007+ R6R i need a quick measurement done with a caliper.
See picture.
Can someone with the stock steering head bearings measure this distance for me, from the frame to the underside of the top triple clamp? in MM
I have put in tapered bearings and want to know if this distance is the same or not.
Please and thanks!!
iRun
Would if I could, but all my stuff is down the road and across the country. Good luck! :cheers:
with the all balls kit the space is about 11mm
i wanted to know if it was the same as stock or a little higher/lower since that affects where you should have the forks in the clamps but looks to be about the same.
Thanks bronco..
1 - 8 of 8 Posts
