I was browsing the web trying to learn about my bike (R6S) in comparison to some of the newer years/generations. Came across the link below for anyone interested.
http://www.totalmotorcycle.com/photos/2008models/2008models-Yamaha-YZF-R6S.htm
There is a ton of info on the actual page itself but I'll throw the actual spec's below.
Engine
Type 600cc liquid-cooled inline 4-cylinder; DOHC, 16 valves
Bore x Stroke 65.5mm x 44.5mm
Compression Ratio 12.4:1
Carburetion Fuel Injection
Ignition Digital DC-CDI
Transmission 6-speed; multiplate wet clutch
Final Drive Chain
Chassis
Suspension/Front 43mm fork; fully adjustable, 4.7-in travel
Suspension/Rear Single shock; fully adjustable, 4.7-in travel
Brakes/Front Dual 298mm floating disc, 4-piston calipers
Brakes/Rear 220mm disc; single-piston caliper
Tires/Front 120/60-ZR17
Tires/Rear 180/55-ZR17
Dimensions
Length 79.7 in
Width 27.1 in
Height 42.9 in
Seat Height 32.3 in
Wheelbase 54.3 in
Rake (Caster Angle) 24.0°
Trail 3.4 in
Fuel Capacity 4.5 gal
Dry Weight 357 lb (CA 359 lb)
