1 - 4 of 4 Posts
· I said biiiiiiiitch.....
Check your starter relay and it's fuse. When you press the starter button it normally makes a "click" sounds. If it's malfunctioning, maybe it's buzzing and not completing the circuit.
If the relay is fine, check the starter motor. You can hook 12v directly to it to make it spin. If it's buzzing, instead of spinning like it should, that's the problem.
1 - 4 of 4 Posts
