1 - 2 of 2 Posts
I’m hoping someone can help, I’ve ridden my bike in the rain washed it down and popped it into the garage for a couple weeks. The bike now starts to rev hunt and I’m getting an error 11 and 14. I haven’t touched or taken anything apart, nor have I knowingly knocked anything. I can get the bike to run, then it starts to rev hunt and then stalls. I am completely baffled.
thanks
Hi there
Error code 11 - No normal signals are received from the cylinder identification sensor when the engine is started or while the vehicle is being driven.
Error code 14 - Intake air presssure sensor: hose system malfunction (clogged or detached hose) / Bad sensor / Malfunction ECU
Do you know how to acess the diagnostic mode ?
You can go on DIAG. mode, choose nº3 , and check it .. the nº3 on DIAG. is for the intake sensor.. (Compare the actually measured atmospheric pressure with the meter display value without cranking the engine)
Pressure difference by cranking the engine with the starter, without actually starting the engine: 10 - 200 mmHg
(BUT im not 100% sure the range is 10-200, i think it is, double check that)
Hope that helps! :)
1 - 2 of 2 Posts
