1 - 3 of 3 Posts
I decided to clean my injectors and fuel pump over the weekend after I put the bike back together, now it doesn’t start or crank. When you try to start it the oil light flashes and you could hear the relay clicking under the seat. The neutral light only comes on when you squeeze the clutch lever in. Any help?
20k+ miles, ECU flash, blah, blah, blah...
Not 100% sure but u should probably go back and take ur time to make sure everything is where it's supposed to be. If bike was working fine before u took it apart then it's something u did or didn't do. If the problem is still there after then check the voltage and follow each wire that's effected from ur injection cleaning.
Hope it helps or someone knows better than I. Good luck🙏
1 - 3 of 3 Posts
