1 - 5 of 5 Posts
Any one successfully get the '17+ R6 headlamps to cover more distance? Not necessarily brighter (though that would be nice too) but to cover more ground. I feel even with high beams on when applicable, they can use a bit more distance.
have you tried aiming them higher? I have an R1 and I think they are pretty terrible as far as headlights go.
the LED lights on the R6 and R1 do not have a "bulb" you can remove to put HID in. you would literally have to modify the lighting setup completely to mount a aftermarket setup.
I understand the LED strips can't be modified, but the actual headlights (kinda tucked away below the nose fairing) are LED as well and not just a bulb?
it looks like it's not able to be opened up. check them out on ebay. I had mine out but it was back in 2016. they dont take a normal bulb style fixture that's for sure.
1 - 5 of 5 Posts
