1 - 3 of 3 Posts
2017 yamaha r6, involved in accident at high speed. Other than general cosmetic repairs, the bike hit a tree on bottom side bending middle exhaust into oil pan which was replaced. The o2 sensor is not connected, have the exhaust manifold connected. Bike will not start. Installed new spark plugs, has gasoline, has oil, in neutral, kickstand up, clutch or no clutch it isn't starting up.....battery fully charged as well. Ive read about possible crash/tilt sensor, but not convinced this is the issue. Only other thing is I accidentally ripped oil pan sensor wire when installing, but as far as I can tell this only blinks on instrument panel. Any thoughts would be appreciated.
Won't start, but does the starter turn? Or does it just do nothing? The fuel pump is activated?
If it were the angle sensor, I'd swear the starter wouldn't work. It could be a switch. After a fall it could be many things.
I do not know if your model, being more modern, has a "blocking" system at the moment of having an accident.
Regards.
Tires tell no lies
I would think its either the crash sensor, or a safety feature not allowing you to start the bike if this oil pan sensor is not connected thinking there is no oil in the bike so it wont start. I would repair/replace that sensor then go from there.
1 - 3 of 3 Posts
