Hello Everyone, thanks so much for contributing to this forum its a great resource for people like me. Hopefully you guys can help me out with this issue.
Im helping a buddy get his R6 back in working order after it was laid down on the left hand side. The bike sat outside for about 6 months, and hasn't ran since the crash The crash broke the left handle off, but only bent the clutch lever and the switch seems to be ok. The stator cover was replaced, and gas tank (filled the new tank with about 1.5 gallons of 91) along with some other various damaged parts. Got the bike all back together, and now it wont start, I replaced the 50amp main fuse which was blown, and the ETV (7.5) fuse was blown also. The rest of the fuses on the bike looked ok. Fuel pump is making normal sound when the ignition key is turned on also. After cranking the bike for a while, I was able to get the bike to turn on for about 30 seconds - 3 times in a row, sounded like the idle was pretty low, but when i tried to rev the throttle, the bike would bog and turn off. After those few times barley starting it just cranks and wont fire again. I changed the spark plugs, and verified there is spark on all four cylinders, not sure why it wont start. I read on here that you need to have a diagnostic module to pull the codes which I dont have, and would like to avoid taking it to the stealer to get the codes out of it. Could i be the clutch switch? Kickstand switch? Coils? fuel injectors? Any help is much appreciated to get this thing going again.
If you need more info, please let me know.....
