2nd Gen Air Fuel Ratio Gauge Install
Many years ago when I was looking to purchasee, was adamant about avoiding any carburetted bikes because I wanted to maximize seat time over tuning and tweaking. Little did I know at the time that the engine control technology in the bike was just a step above carbs. It doesn't have an oxygen sensor in the exhaust. So it has no ability to self-tune on the go. No knock sensor to back-off timing.
Taking it to a tuner seems like it'll be a regular affair at this point; more especially with all-season riding.
Anyone installed one to their 2nd Gen? What did you use? Any recommeendations?
https://www.amazon.com/gp/product/B00N3VGPYS/
https://www.amazon.com/gp/product/B003V94GLQ/
https://www.amazon.com/GlowShift-Black-Color-Needle-Wideband/dp/B0752TKSKM/
This should provide me with the data needed to help compensate for the absence of an oxygen sensor.
Already have a relayed SAE terminal installed.
Splitter bought.
HOW TO: Hidden Air Fuel Ratio Adjustment
Tip sourced from R1 forum. https://www.r1-forum.com/threads/adjusting-air-fuel-mix.62758/ Add-ons, such as the Power Commander, are not required for this. Second Gen R6 instructions are slightly different from above. Be sure to record your original numbers, prior to making any adjustments...
www.r6-forum.com
HOW TO: Relay that SAE Terminal
I'm adding a USB Charger to power my GPS for longer trips. https://www.amazon.com/gp/product/B01N7CHYCF/ https://www.amazon.com/gp/product/B07N1993MV/ Amazon.com: Techmount 4-10105 - Universal Motorcycle Fork Stem Mount Kit - This is a Mount only and Does not Come with a Cradle to Hold Your...
www.r6-forum.com
Splitter bought.
Amazon.com: AYECEHI 10AWG SAE Connector SAE DC Power Automotive Adapter Cable Y Splitter 1 to 2 SAE Extension Cable 10AWG 1.3ft/40cm - with Waterproof Cover : Patio, Lawn & Garden
www.amazon.com
