So, I insallted a AFAM Sproket kit with a WX Gold RK chain. After installing it I have a noise comming from the Primary Sproket / Chain. Nothing is rubbing, I took it apart to make sure it was good. Sounds like something is dragging.
When I took the Primary sproket off, I used a socket/ratchet. Did I maybe bend the shaft that the sproket fits onto? Is this posible? Standard 8" ratchet.
Any who, is this a normal noise when you convert? I only hear it when im in 3rd 4th or off the gas.
I can send sound clip if need be.
OR is this sound normal for the new sprokets/chain?
