I have a 1999 R6 that is acting up. When the bike is in Neutral it runs fine no issues and I can rev the bike up to red line with no issues. The problem comes when you go to ride it in first gear I can get it up to about 12K rpms and in second gear I can get up to 10K RPM in all the remaining gears it will not go past 8K rpms.Under hard acceleration it is like hitting a brick wall and I can keep the throttle wide open and it will just stutter along at those rpms and cruise down the road but won't produce anymore power. I can back off the throttle and ease it back up and sometimes it will climb to a higher rpm but not much higher. Has anyone else dealt with something similar?
Here is what I have tried so far with no luck.
Changed fuel filter, fuel pump, oil and spark plugs. I have cleaned the air filter, cleaned the carbs, jetted the carbs, I've tested the charging system with a voltmeter, I've tried running the bike with the headlights disconnected, I have looked for pinched air or fuel lines. I have checked the headers by spraying with water and all cylinders are firing, I have checked the coils with voltmeter and they tested alright but I had an extra set of coils in another running bike so I swapped them out for shits and giggles. I'm sure I am forgetting something but even after all of this there has been no significant or noticeable changes!
:bash I'm running out of ideas and I really want to get this bike running!
