Hey yall recently picked up a bit of a project bike, 2003 R6 with 66k mi on the clock. Now I've fixed just about all the issues but there's a couple that I'm not quite sure what is causing them, or would like some advice before spending big bucks.
There seems to be an issue with the front brake, where under braking it kind of rocks back and forth or pulses, almost like abs. It's extremely noticeable when under light pressure, as I'll slowly becoming to a stop and the brake feels like it's grabbing harder at one spot. I immediately suspected the rotors, but had them inspected and straightened but didn't solve the issue. The master cylinder was also replaced, and have brand new brake pads, still no fix.
The other issue I think is with the front suspension. Under hard braking force, or engine braking, it feels like the front vibrates or shudders. This is the one I'm expecting the front forks might need to be replaced, but wanted some opinions. I adjusted the front suspension because it was extremely stiff from the previous rider, but didn't help the issue.
Thanks all!
Thanks all!
