OK, I need your guys help. I know alot of you have really good knowledge of R6's and maybe someone can help me out.
My 02 R6 has 16000km's on it, still in pretty good shape. The problem is as follows.
My bike is really flat at 7K...it does alot of jumping or bucking, almost like if you were to hit the throttle just a little bit and then back it off. I know most R6's run really lean to begin with around this area, but is this the sign of a fuel system or carb problem. It also is really jumpy in first gear, and it does alot of "popping" from the exhaust (hindle slip on).
I just finished changing my plugs and my air filter, both new OEM products. This didn't fix the issue at all, if anything, it seems more pronounced but maybe i'm so keen on spotting it now, it seems worse.
Has anybody experienced this, and is it a problem or just the way it is for this model? any suggestions are appreciated.
BTW, this site rocks, i've gotten so much good advice so far, but i've been mostly a lurker.
