1 - 20 of 21 Posts
LHRB
Lots of older threads on aftermarket wheels, but nothing recently.
Looking to upgrade the wheels to a lighter set without spending carbon prices.
Good read on why lighter wheels:
Anybody try these wheels? Very light.
APEX-6 YAMAHA R6 2017-2019 FORGED CORE MOTO WHEELS
Bare Wheel weights.
FW35LM1 Front: 5.79 Lbs
RW6LM1 6" Rear: 7.96 Lbs
RW55LM1 5.5" Rear: 7.84 Lbs
MARCHESINI FORGED ALUMINUM WHEELSET: YAMAHA R6
OZ MOTORBIKE PIEGA FORGED ALUMINUM WHEEL SET: YAMAHA R6 '03-'15
OZ Motorbike GASS RS-A Forged Aluminum Wheel Set 2017-18 Yamaha YZF-R6
Front: 17 x 3.5"
Weight: 7.7 lbs
Rear: 17 x 5.5"
Weight: 9.7 lbs
I wouldn't trust the published weights. Is this for street or track? A set of BSTs is $3200 all day long. Not sure why you would not spend the loot when they are all over $2000 anyways. Make sure you get the proper valve stems.
LHRB
Discussion Starter #3
Street and track use.
I had a set of BSTs on a Panigale 959 and they were amazing.
Looking to try an aluminum wheel.
Didn't your bike come with aluminum ones?? lol.
Id worry about the cush drive rubbers. I was lucky a few years ago and got a lifetime supply
of cush urethanes for my bikes with aftermarket wheels.
LHRB
Discussion Starter #5
Still thinking about wheels.
The BST is tempting. May just start with the front.
LHRB
Discussion Starter #9 (Edited)
FWIW
Published weight of the BST is 5.9 lbs without bearings,add .4 pounds (6.4 ounces) with bearings = 6.3 lbs total.
The website indicates OEM is 8.8 Lbs.
375572
LHRB
Discussion Starter #10
In case you are interested, this is the weight of a stock 2018 ABS R6 front wheel with stock rotors and a 50% used Pirelli TD supercorsa.
When I mount the galfer wave rotors on the BST and mount the same tire, I will post a comparison.
375616
LHRB
Discussion Starter #11
22.5 lbs with galfer wave rotors for a weight savings of 14%
Not as dramatic as I would have thought but the weight savings also puts less of the rotating mass on the outside of the wheel . Such is the claim but I have no evidence of such.
375639
LHRB
Discussion Starter #13
This is an interesting read:
* Carbon race front wheel was 15% lighter but had a 25% better inertia figures .
* Carbon race rear wheel was 10% lighter but had 33% better inertia figures .
is there any kind of coating on the bead of the BSTs?? I would put a tape line on the wheel and a paint mark on the tire... just to see if the tire spins on the rim under hard braking.
LHRB
Discussion Starter #15
Yes, the bead is grippy, not glassy and slick like the outer finish. Not a bad idea to mark the rim and tire though.
LHRB
Discussion Starter #18
The OZ wheel is 20% lighter than the stock OEM wheel (NO OEM rotor and phonic wheel installed, no sprocket or carrier)
OEM 13.3 Pounds
Oz Piega 10.6 pounds
375689
375690
LHRB
Discussion Starter #19
All in all, with the superlite steel sprocket, same tire, the OZ piega rear comes in about 10% lighter ready to mount on bike.
OEM rear, stock rotor, sprocket and carrier, Supercorsa TD tire 50% life: 32.5 pounds
OZ Piega, stock rotor, OZ carrier, superlight steel sprocket, Supercorsa TD tire 50% life: 29.7 Pounds
375693
375692
LHRB
Discussion Starter #20 (Edited)
FWIW I had to use a propane torch and an impact gun to break the stock rear rotor bolts free. Re-used those bolts for now. Not recommended.
Ordered a set of titanium bolts from Pro Bolt USA Professional Motorcycle Bolts and Fasteners | Pro-Bolt USA to replace them at some point. Re-used the stock bolts on the new OZ wheel but I am not comfortable with those bolts after having to heat and hammer them to get them out.
Should be good enough for one more track day ... I hope.
The new front wheel rotors have black titanium bolts from Pro Bolt. Nice pieces.
Two tools I highly recommend if you remove your wheels more than once per year.
1 - 20 of 21 Posts
