1 - 2 of 2 Posts
So the Akrapovic site has two slip ons available. I googled it and searched the site as best I can.
S-Y6SO9-ASZ and S-Y6SO9-HASZ. Model S-Y6SO9-HASZ looks to have a power valve attached, while S-Y6SO9-ASZ does not.
1. I can only get the one without the exup valve(ASZ) - I'm assuming when its fitted you either tuck the valve cables in somewhere or remove the cables and install an exup eliminator?.
2. If you just leave the cables hanging, its not damaging the unit? I'm guessing the cables still "work", so you dont get the error code? It doesnt damage the mechanism/cables long term? Any tips on where to tuck them in? Or do I still need the eliminator?
3. The actual valve is in the slip-on? So when the stock slip-on is removed, you remove the entire thing with it?
Whatever happens, happens
Yes when you pull the slip on off, the valve goes with it. Disconnect the cables and it's free.
Just do yourself a favor and get the EXUP eliminator plug. You can take off the EXUP motor then too. It's pretty easy to do.
1 - 2 of 2 Posts
