1 - 4 of 4 Posts
have a 2007 R6 and every time i let off handle bars or keep the front wheel up it leans right ive had it checked out and everything seems fine chain adjuster and chain is all straight everything look fine but it bothers me when i have the front wheel up i could have my whole body to the left side and it still leans right any help or anything i should check?
would my forks have the play in it though because like i said it leans right even when im on 1 wheel for a period of time which is what i dont understand.:serious:
missed that. Sounds like your rear axle is not aligned.
make sure you use a the 6mm allen trick when you tighten your axle...
Q
1 - 4 of 4 Posts
