Yep... I ALMOST lowsided the other day.
Let this be a lesson to all of you guys. I hope I can help you all out.
Story Goes...
I leave for work at about 515AM the other day. Get out of my neighborhood and turn onto this little "shortcut/fun" road on the way to work. Going about 50 down the road, and come up on my next right turn, so I downshift into second and get onto the brakes, let off the brakes and start to lean it. (Imagine a T inter section, there is a pickup opposite direction to me, and a car at the stopsign perpendicular to the road I am turning OFF of, another car 100 yards down the road approaching the stopsign)
SLIP!!! the front tire STARTS to go out on me mid turn. So without even thinking about it, I kept my head up and jammed my wheel the way I was sliding, Pinned the throttle for a half a second and looked across the road into *and through*the opposing traffic's lane (behind the stopped car, but IN FRONT of the approching car) The bike stood RIGHT UP, and bucked a little back to the left. Went RIGHT between the two cars and into a little dirt spot on the opposite side of the road, kept it rolling throught the dirt, got BACK onto the road, (now driving the wrong direction in the OTHER lane) and the car approaching the stop sign just kept on going, the car opposing me (before I turned) passes by in the OTHER lane (headed the same direction as me) and I just keep rollin on down the road get back into the correct lane, and continue on to work.
I get to work and I have decided (my mind is SET) that I screwed up, I was on cold tires, the road was cold, (50 degrees that night) and I "over broke" going into that corner, It was all my fault.
So, I head home that after noon (the same way I came to work) to investigate my little Slipping incident. Get back to the corner where I ran into the dirt, and pull off and park the bike. (There was NO traffic at this time) I get off the bike and go walk out into the T intersection. Spot my tire slip mark (about 4 feet long) and notice a little bit of sand (not much) and A FORK! an eating utensil a metal FORK! as well as a Scratch in the pavement, where the fork had been slid across it.
I slipped on a frigging FORK! and I almost lowsided because of a FORK. Here I spent ALL DAY thinking I was an idiot for "over braking" into a corner, and that it was my own faulf that I slid out a little, and It was a FORK that caused the whole thing.
Well, I am okay, and so is my bike. As for the fork, I don't think it will be getting used again because I picked it up and Disposed of it properly.
Lesson for the day. If you come upon a fork in the road, don't try to run it over while turning. It may cause you to slip.
Ride Safe out there, and stay away from forks!
Story Goes...
