Vendor
Fall is here, but don’t let the cooler weather stop you from enjoying your bike! Alpinestars Winter Tech Performance gear has you covered with motorcycle base layers in the form of a long-sleeved shirt, long underwear or a full coverage one-piece suit - all of which help make cold-weather riding enjoyable again. Dual-density fabric is employed in the areas most likely to be exposed to the elements and necks are high to keep the blood flowing to the brain as warm as possible. Every piece is made entirely of a polypropylene and elastine fabric that’s assembled without conventional seams for a comfortable fit close to the skin. As an added benefit to thermal stability, each garment is of a compression fit design to reduce muscle fatigue and improve rider performance in adverse weather conditions.
Motorcycle winter riding gear from Alpinestars is available to fit sizes X-small to XX-large. Learn more about Alpinestars Winter Tech Performance gear by clicking here then call MIKE at 866.931.6644 ext 804 to order. You can also send email with your questions to FORUM at RIDERSDISCOUNT dot COM with ALPINESTARS WINTER GEAR in the subject line and we’ll get back to you right away.
Alpinestars Winter Tech Performance Top employs a comfortable moisture-wicking fabric that will keep you comfortable for many cold-weather miles.
Alpinestars Winter Tech Performance Bottom.
Alpinestars Winter Tech One-Piece Suit includes two low-profile zippers to help you get into and out of the suit but won’t chafe against the skin.
