1 - 2 of 2 Posts
Vendor
One of the coolest looking helmets to come across our desks lately, the Arai Signet-Q Hydra features a large Dragon with vibrant blue, red, and green colors laid out on a black frost base. Available from Riders Discount, this long oval helmet can be yours today!
Order your new Arai helmet through our website here or give Brad a call at 866.931.6644 ext. 810 for any questions you may have. Is email more convenient? Send us a message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
The Arai Signet-Q looks nearly identical to the RX-Q and shares many of its features. These include the wide field of vision, quiet and efficient ventilation, brow-vent shields, and the Hyper-Ridge. If you’re not already familiar with the Hyper-Ridge, it’s the distinctive band that runs around the bottom of the shell. It not only provides a lower center of gravity, but also improves strength and aerodynamics. Despite these similarities, the Signet-Q is an entirely different model, which becomes clear when you take note of the differences.
The most significant difference between the Signet-Q and the RX-Q is the shape. The Signet-Q is actually 5mm longer from front to back, meaning that it is what Arai calls a long oval. Additionally, the Signet-Q has peel-away pads in the headliner that allow you to customize the fit on the sides of the head right out of the box. A new, more comfortable cheek pad system, called Facial Contour Support (FCS), was also added to this model. The new cheek pads feature an innovative design that puts just the right amount of pressure on the cheeks to give a secure fit and to keep wind noise out while being worn, but easily pull aside when putting the helmet on or taking it off. Like the headliner, the cheek pads also have a 5mm layer that can be peeled off to dial in the fit.
Vendor
Discussion Starter · #2 ·
This great looking helmet is available and ready for you to purchase today!
Give Brad a call to order your new Arai Hydra from Riders Discount!
1 - 2 of 2 Posts
