1 - 20 of 27 Posts
Hi fellas, I just installed my Armour Bodies bodywork on my 2010 R6. The install and git has been great, of the 3 types i have experience with this has been the best quality and fit so far.
Question, for those who have the bodywork, how did you install the windscreen? I have a zero gravity windscreen and the tabs at the very bottom do not line up with the mold. it pushes it up from the bottom and leave a little gap. Are you supposed to grind off the tabs on the windscreen? or cut slots into the fairing?
track junkie
i've been installing the same kit on my 09 r6. haven't got my screen in the mail yet, but i was wondering the same thing after looking at the stock screen.
also, how did you affix the bottom half of the tail section to the top half? any pics? this is my first fairing install...
s3aturnr
Discussion Starter #3
I haven't actually installed my tail yet but I will be using Dzus D-Rings. In the past i have just used the push pin rivets off the stock R6 fairings and I have never had an issue BUT i think the D-Rings will be more secure.
s3aturnr
I'm in the same boat.. will be tackling on an '09.. and using the Dzus fasteners (rivet style)..
going to follow the write up on the board already but.. of course my results usually vary haha
Discussion Starter #5
I called Woodcraft as they are the US distributors and they told me just to bolt it right up and that it was ok to have the gap. The guy I talked didn't fill me with confidence that he knew what he was talking about. But if this is what you are a really supposed to do that's fine it's just a pretty poor fit if you as me for a kit whose fitament is near perfect everywhere else. I tried calling their Armour Bodies headquarters and got no answer and their mailbox was full... dang candadians:sing
Pin it to win it!
Yes grind the tabs off the Zero Gravity. That's what I did and have been happy with the fitment. You could cut holes in the upper for the windscreen to slot into, but that wouldn't be my first choice.
When I installed mine I had the same issue. The whole kit fit great, but the windscreen sat cockeyed as the holes did not line up well!
BTW, DZUS is the way to go
Discussion Starter #8
That's what I did and it fit's great. Thanks Parapuke. For those considering the armour bodies kit you will need to do this to have a clean fit of the windscreen. I have a grinding wheel and I was done in 5 minutes.
Pin it to win it!
Just FYI this is required for probably most bodywork. I've mounted Sharkskinz and Armour Bodies this way with the windscreen. Most companies don't want to put extra holes in there product and since the windscreen tabs aren't really necessary, this is what they do.
Discussion Starter #11
Good to know, i have worked with FBW (factory bodyworks) a and the FBW doesn't have the faux dash like the Armour bodies one so you just tuck the entire front of the screen under the body.
I used the puig windscreen with my 2008 and had no fitment issues. Armour bodies is the nicest set of bodywork that I have installed. No cutting or grinding necessary.
Discussion Starter #13
Yeah the puig screens don't have the tabs like the Zero Gravity or stock ones do. But I agree one of the best fitting kits i have seen.
My R6 eats Wheaties.
Puig FTW. I have the Puig Z screen, looks awesome and fits great on the Armour Bodies on my 08.
fyi, zero gravity makes a "race specific" screen that doesn't have the tabs and instead of the wavy design to fit the mirrors, it's just a flat tab so you can secure it to the fairing stay better.
Discussion Starter #17
Didn't know that, i will probably pick up another screen when it's time to paint the fairings.
1 - 20 of 27 Posts
