1 - 2 of 2 Posts
my 06 has some issues with the clutch, when the bike is stopped with the clutch pulled in gear, the bike wants to pull forward but while the clutch is pulled and i rev it a lil then it pulls backwards...it shouldn't pull at all but i have adjusted the clutch cable on top and underneath and it makes it better but doesn't fix the problem was wondering if I should look into a clutch rebuild or if its something else.
My R6 eats you.
Make sure the clutch cable is adjusted correctly and that you have fresh and the appropriate oil in the bike. Typically when a clutch goes bad it will slip or make gear changes difficult.
1 - 2 of 2 Posts
