1 - 8 of 8 Posts
I put a multimeter on the battery of my R6 2001 and the Volts dropped to 8.6 while cranking. Then back to 12+ while running.
does it need to be replaced? it is several years old already.
thanks gang!
I believe the minimum it should be able to maintain during crank is just above ten volt.
This of course assumes that the mechanics of the engine/starter are good; wiring.
Running voltage by the way should be battery voltage (if fully charged) or above.
Running on a bad battery supposedly stresses the charging system because they're not designed to run at high field for extended periods. It's cheaper to replace the battery now, versus replace a stator later.
Discussion Starter #6
yes I agree, I meant now, as in winter is coming and being 7 years old it wont make it through the next cold period.
I have to reread up on Gel tech, but memory serving, I believe AGM is supposed to be better.
1 - 8 of 8 Posts
