1 - 20 of 21 Posts
My R6 eats you.
Ordered a ZFI for my 07, was sent one for an 08. Any issues with this?
R6 Junkie
Maybe ask Agg? i think i saw something he posted about this and having to re-set the TP settings or something? had to do a power run on a Dyno for wide open throttle?
My R6 eats you.
**** that, this is like the only thing I bought new so I could save myself the headache...
My R6 eats you.
I'll wait to hear from them before I mention the vendors name..
My R6 eats you.
Alrighty, thanks for the help Corey.
My R6 eats you.
Discussion Starter · #13 · (Edited)
Just to update this thread:
Corey,
That is correct. All of our maps are provided on the website for the end
user.
Regards,
Del Edlefsen
Sales Lead
BazzazLogo
15330 Fairfield Ranch Rd. Unit E
Chino Hills, Ca 91709
909-597-8300 O
909-597-5580 F
www.Bazzaz.net
-----Original Message-----
Sent: Friday, December 10, 2010 10:33 PM
To: [email protected]; [email protected]
Subject: confirm
Just to confirm the 06-07 R6 and the 08+ R6 ZFI units are the same other
then the map that is inside them correct?
Corey
MotoMummy Staff
Once I installed the software and connected the Bazzaz it showed the 06-07 map was already installed. Thanks again Corey. :cheers
bazzaz tech support told me that the TPS on the 08+ units HAS to be recalibrated on a dyno to be used on the 06/07. but oh well... good luck man.
My R6 eats you.
Discussion Starter · #15 ·
I don't see why. It uses voltage to determine the throttle position. I calibrated it by turning the bike on, but not starting it, and setting the voltage of the throttle closed then voltage of the throttle WFO in the software...
It's pronounced "Tollz"
WFO.. :hehe
You can't calibrate the TPS with the bike off.. Chris (@ Bazzaz) told me there's gotta be load on the engine to achieve the correct calibration. So, basically you need a dyno run to calibrate WFO
no, b/c i was asking the same question. i was looking at an 08+ zfiQS and del said it had to be recalibrated. i hope for colin's sake it doesn't - not that a few "horsepower runs" are expensive, but it's just a pita to have to work that into a build.
edit: why don't you just return it for the correct year?
My R6 eats you.
Discussion Starter · #20 ·
Ok I just called Bazzaz so we can put this to bed. No difference at all (besides the maps) between the 06-07 and the 08. However I did **** with the TPS calibration, and that can't be reset, so I either have to do dyno runs, or send it back to them to have them reset it.
1 - 20 of 21 Posts
