1 - 11 of 11 Posts
· www.1seven1.com
I tried for months to get an FiTC with no luck and kind of got the runaround from Bazzaz. I ended up getting the full range of dynojet bits and had them dialed in by Dynojet at the track. Results are awesome.
I've heard about quality issues with Bazzaz but don't have any firsthand experience. The closed-loop O2 sensor concept is a good one. Having TC so I could whack that throttle when my tires are going off would be great! :D
Post up and tell us how it works! What system did you end up ordering?
-D
Ok.... I received my Bazzaz today.... BMC filter is yet to come... and I have only 41 miles on the R6.....
So .. My question is this.......Do I install and Bazzaz now.... or wait for the filter and or wait till the engine is broken in?
Re: Bazzaz..... When to Install It.....
Need a little advise on when to Dyno.....
I received my Bazzaz today.... BMC filter is yet to come... and I have only 71 miles on the R6.....
· www.1seven1.com
Go for a good ride this weekend. Stay off the freeway so you don't hold the throttle at the same position for an extended period. Don't worry about getting on the gas, just don't run it to readline. Pull over and let the bike cool down a couple times (lunch or something). Get 300 miles under your belt, then ride it hard with some bursts of RPM.
You'll be ready for the dyno next week when you get your filter. :D
-D
· www.1seven1.com
What the heck is a bazzazz?
Edit... Oh I see, It looks like a one off F.I. mod. gotchya
With quickshifter and traction control, closed loop O2 sensor and push-button traction control adjustment. Cool stuff if it works as claimed. There's an article in the new SportRider.
-D
· Shiney up Rubber down
-D
ah HAH! I see. I may have to go to the store like a bum and sit there and read a little about it.
Thanks for the info man. (I googled it and all it said was that it was FI control)
· Premium Member
SpidermannSS just put the Bazzaz on his bike during this year R1/R6-Forum Convention. It took a couple of hours for us all to install it, but was fairly straight forward. The traction control sits on your left clip-on. His bike ran pretty well after the installation. He seemed pretty please with it.
1 - 11 of 11 Posts
