1 - 5 of 5 Posts
droping the front would definitley not hurt it if you did just 5mm it would turn better for sure it might get a bit flighty but if you've a damper and frankly i would'nt ride a bike without one you should be okay!
the dazzler
It depends on why/how you want to lower it, If you just want it lower to the ground over all, you'll have to lower both the front and back with a slight bias toward the front so it'll still handle light. If you just want to lower the front to help it turn in quicker/easier, then as long as you dont go too far it shouldnt be a problem.
1 - 5 of 5 Posts
