1 - 2 of 2 Posts
I have 2 projectors / housings from an audi A6. However they dont have the movable high beam flap and solenoid. If i purchased the bi-xenon setup that has a solenoid in the actual bulb holder (bulb pivots when highs are switched on), would this work with those kind of projectors.
bi-xenon setup is the projector. It doesn't move the bulb though. It moves the metal piece inbetween the bulb and projector lens. Basically, if you bought a bi-xenon setup, you'd have two sets of projectors. Depending on what you got, you might be able to mix and match between the two projectors, but it probably wouldn't work and wouldn't be worth it. Know what I'm saying?
1 - 2 of 2 Posts
