Hi as title says. It is a 2001 year R6 carb model 5eb engine, compression is fine on each cylinder 180 psi, I no they suffer crank breather problems but this still cuts out when I disconect pipe and there is no high pressure there.
Checked coils, Cleaned carbs and done valve clearence yesterday. Got told even if they not set 100% correct the bike would still not cut out like this. It runs lovely till the temp creeps up then wham engine cuts out and it is hard to start again unless you have the throttle fully open so I am at a loss here now.:mad::mad::mad:
