1 - 4 of 4 Posts
I had my bike jacked up to get the fork seal and front wheel swap.
I then started the bike up, and i notice in neutral, the rear wheel will rotate if i make the chock richer. Is that suppose to happen? I thought in neutral the clutch is fully disengage.
If my assumption is right, then i think my clutch is old. FYI, my bike has 35k miles. I tried to adjust the clutch cable, but its the same.
thats just the residual turning motion being transfered through the friction in the oil and bearings grab a hold of it if it stops your fine and it WILL stop if your in neutral if not your in gear
Nothing wrong there. If you can rest your hand on it and it stops youve got no worries.
+1 on Nitros post, its just friction moving everything about cause its so tight in there :p
UnZUnDUnR
Whats your idle speed?If its just a little too high.The rear wheel will turn when not touching the ground.It should idle around 1300rpm.
1 - 4 of 4 Posts
