1 - 3 of 3 Posts
I have a problem with my bike moving in gear. When you click down and release the clutch, the bike just sits there as if it is in neutral and doesn't stall or move for that matter. I've taken the clutch apart and have put it back in with the proper procedures but all to no availability. The clutch cable has been replaced so I know that it is not the culprit. Any suggestions?
When you replaced the clutch cable did you adjust it correctly? Make sure you can fit a quarter between the perch and lever. Also, if your speedo is still reading but the bike isn't going anywhere, you either lost your chain, or your front axle nut came off. The second happens quite often so pull off that cover and make sure everything is still connected.
The clutch cable has been adjusted correctly. There is no slack and when you pull the clutch lever in, the small metal hinge on the bottom of the clutch cover moves and snaps back into place when you release the clutch. The speedo does not read anything either.
1 - 3 of 3 Posts
