1 - 11 of 11 Posts
Ok here we go a friend of mine yamaha r6 is not starting the fuel pump is working and so on...if you dope the bike it would start when we checked the upper injectors there aren't getting any current when trying to start
Need more info on the year, etc. it might be the resistor in the keys ignition.
They will cause a crank but no start condition.
Sent from my SM-G965U1 using Tapatalk
Discussion Starter #5
Its
2008
So how would you know directly if it's the resistor?
I wanna say it's going to be the blue and black wire since it feeds stright back to the PCM. If it has 0 ohms on it or less than 5 it's bad and not giving the PCM the reading it needs to fire everything off.
Parts Pimp
Dope the bike?
I presume he means spraying flammable fluid into the intake.
Do you have any codes stored?
If you're 100% confident that your injectors aren't firing:
The voltage regulator feeds the injector fuse
which feeds the starting cutoff relay module
which feeds the ECU, fuel pump and injectors
The ECU grounds an injector when it wants to fire it
So see whether the starting cut-off module is getting 12v at its red wire.
See whether its outputting 12v on its red/blue wire.
Test for 12v at the ECU's red/blue, and the injectors red/blue wires.
If you have power to the injectors then the ECU for whatever reason isn't firing them. It's unlikely that all would simultaneously go bad. More likely is there's a problem with the fuel or spark.
1 - 11 of 11 Posts
