So I crashed my bike and had to replace the lower engine block, the generator rotor, and the stator. After I replaced all this, it was acting funny. the engine misses a lot as if it's not firing and it has no power after first gear. I tested the stator and it was only reading around 10 volts ac current. It should be higher so I went ahead and got a new stator and it is still only around 10 volts. I think it is an ignition issue, the bike not getting enough power from the stator to ignite properly. Any thoughts appreciated. I know it's confusing sorry haha!
