1 - 3 of 3 Posts
So this bike was crashed.When the wheel is straight the triple mount looks a little turned doesn’t look like it’s straight.When the triple mount is straight the tire is slightly turned.The turning radius for the left side is way better then the right.see pictures please.I have so much left turning radius but no as much when turning right.what could this be
Looks like your front forks are twisted. Fully loosen front forks all 3 squeeze bolts (each), set everything straight and tighten again. And hopefully that'll be it. after such an extreme twist check that your front suspension is not damaged and compresses correctly. Don't want a tank slap.
Get a service manual. Tear it down while taking lots of detailed photos from every angle with your phone. You want to be able to refer back for cable and wire routing + tie-downs. (important on a motorcycle)
Build the front end back up using the following instructions + service manual. Ignore the part about replacing the forks. That isn't the point of this. Only replace the forks if there is evidence of damage... which there may not be.
1 - 3 of 3 Posts
