1 - 3 of 3 Posts
TJ
Ok so i got flush mounts off ebay and they have a red wire and a white wire, which i assumed were hot and ground. I have an 04 r6 and found out the three wires from the harness on the bike were as follows: blue is running lights, brown as blinkers, and black as ground. So i wired up the left blinker and taped off the blue wire and it works fine. Then i wired up the right one and now the right rear blinker, the front right one, and the blinker indicator don't work. I unwired the right one and the rear right and indicator work again. I don't understand how this is. I have checked the signal fuse and it is fine. Any suggestions?
MACGYVER 05 R6 NJ
Rewire the old blinker back. If it works then you may have a bad blinker or you need a flasher relay. Test the blinker buy wireing it up to a 12v battery.
TJ
problem is i don't have the old blinker, it got trashed when i laid it over a while back..but i'll try the battery idea
1 - 3 of 3 Posts
