1 - 8 of 8 Posts
...Slow...
My '06 50th...
Pulled the OEM plates off and it left the reed assembly on the inside...I've been following this guide here: AGG Block Off Plates Install - How To
But is it different for the 08's? I can't get the black gasket/reed assembly out of the housing. It just pulled the cap off when I tried pulling the stock ones off and I can't get them out. Am I missing something, or should I just keep trying to work them off? Almost looks like AGG's plate will fit right over top, but according to all the guides, I need to get that out and remove the reeds and screws. Pics below.
...Slow...
Where at? Just pry in between the metal and the black rubber/plastic?
...Slow...
Got em' out, but damn they are tough little guys.
Last step is to pull those reeds out and just pop the black gasket things back in? Then the AGG plates on top, correct?
...Slow...
Got it all sorted out - thanks! :cheers
Each of those outer bolts for the plates were a PITA. Took forever to get them screwed in, but everything's good.
1 - 8 of 8 Posts
