1 - 17 of 17 Posts
Hello everyone,
This my first post as well as about my first bike. I have a 2004 Yamaha-R6. I purchased it a little over a month ago and with winter setting I'm following the lead and completing/learning to complete all necessary maintenance during this time. the first thing I want to do is replace the front and rear brake pads. Ive seen the you-tube tutorials and I am pretty confident in my ability to do it. However, there are no tool/part lists. This is where it can go south in hurry. Does anyone have a part/tool list for changing brake pads?
leatherman, duct tape...job done
Oh wow, beer and duct tape, makes perfect sense. The beer helps the duct tape stick? Thanks.
Do you not have a toolbox yourself?
The whole bike can *almost* be torn apart with a phillips, 8mm, 10mm, 12mm, and a one way screwdriver.
I'm sure that with those 3 sockets you could do a break pad change.
None of these videos show the guy with a ratchet or tool of some sort?
Yes I have a tool box. However, I'm sure I dont have "Everything" I'm supposed to change brakes. Nor do I "know" what I need. "1st time" remember. Yes I did see the video but I couldnt see the numbers on the sockets. However, the last persons post let me know I will need at least an 8mm-13mm sockets, a Phillips head. You all have done this probably a trillion times I havent. I just want to make sure I have everything I need when I get started because I hate stopping to go to the store to get a $3 tool to do 10 seconds worth of work. My bad, if my question is too newbie for this Forum however thanks for the info.
Other than standard tools that anyone SHOULD have,you will need something to compress the pistons back into the calipers. I use a C-clamp but most auto parts stores sell a caliper piston compression tool.
also if you havent bought pads yet, theres a great seller on ebay, i just bought both front brakes and the rear brake EBC HH pads for 110$ shipped.
Thanks Dustin, Cheefar, and Quik,
From you three, I ve learned that I should have or need a Tourque Wrench, a C-Clamp, and least 8mm - 12mm sockets. That alone was worth asking the question. I have some metric sockets but only 1-8, no use for a tourque wrench so I have get one, no C-Clamp either. So thank you three for not taking my question for granted. Also, I have to check the owners manual to see what size the axle nut is to get a socket/wrench for that as well. I'll check out that seller on ebay for the pads.
Thanks again.
you can do without a torque wrench, thatll probably be the most expensive thing.
I like to torque everything to spec but just be careful, there are definately mistakes in the service manual about torque specs. one that i know of for sure is the specified torque for the self-locking sprocket nuts on the rear wheel.
The manual says to torque these nuts on a 2003 r6 to 72 ft pounds, which is a HUGE mistake, more then double the actual recommended torque of 32 ft/lb which is still a little high.
just be careful, and use blue loc-tite to secure the caliper back on if you decide to take the whole thing off.
My headlight is burnt out
You might want to think about new brake fluid too if you are changing the brakes. If you change the fluid, speed bleeders FTW!
No problem man, I believe the front axle is a 36mm, someone correct me if I'm wrong. Like already said a torque wrench isnt really needed but some blue loctite is a great investment.
uh the axle nut is smaller than 36 mm, 36mm is for the triple tree nut.
I use a 1' 1/4th inch socket for my rear axle, its slightly loose, so i believe the real metric size is 32mm, 1' 1/4th inch works fine though.
i know for sure the rear is 32mm I guess that is probably the one he was asking about
yea the front is a little different, you undo the pinch bolts and then use a 19mm hex key to loosen the spindle, hex key isnt necessary but makes it easier especially if its the first time taking the wheel off.
1 - 17 of 17 Posts
