1 - 12 of 12 Posts
Vendor
Braking's top of the line OE replacement SK2 rotors are available from Riders Discount! Available for numerous models, these are a great, affordable upgrade to your braking system.
Pictured for the Yamaha R6
Commonly seen on many AMA race bikes and throughout the trackday paddock, take a look at any bike's front rotors and you'll likely see Braking rotors installed.
SK2 rotors are directional, please take note during installation. The SK2 rotors are directional because this was found to permit better ventilation during braking and improved the temperature stability, even during racing use.
Outer and inner diameter of the disk have a non-round design that enables better radial expansion of the rotor under extreme heat conditions. Moreover piercing holes are replaced by edges specifically designed to grow brake pad regeneration process.
If you're interested in these Braking rotors, or looking to upgrade any other part of your brake assembly, shoot Brad a message through this forum or give him a call at 866.931.6644 ext. 810. Is email more convenient? Write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Vendor
The Braking SK2's "non-round", or more commonly referred to wave design, allows for high heat dissipation resulting in stable, predictable power in all braking conditions. Combine that with an overall lighter weight rotor versus stock, and you have an exceptional brake upgrade for your motorcycle.
Give Brad a call today to order yours!
1 - 12 of 12 Posts
