Brembo brake calipers have earned a reputation for stopping the fastest riders on Earth thanks to the high level of engineering that goes into every Brembo motorcycle brake product. Brembo HP calipers are no exception. We have these on hand to fit most late-model Japanese sportbikes with radial-mounted 108mm caliper bolt spacing. The entire Brembo caliper is CNC-machined from aerospace-grade billet aluminum and equipped with 2 x 30mm/34mm aluminum piston pairs for superior feel when compared to OEM brake calipers. These calipers are the ideal solution for any rider - from the street to track to racing, who is looking for significantly better braking performance. Brembo High Performance Radial brake calipers come complete with sintered metal brake pads that are compatible with OEM and aftermarket brake rotors.
We also service a wide range of performance braking needs from complete kits to master cylinders and brake pads. Call MIKE at 866.931.6644 ext 804 for expert fitting guidance and fast shipping. You can also email us with any questions you have, send those to FORUM at RIDERSDISCOUNT dot COM with BREMBO CALIPERS in the subject line along with the model and year of the motorcycle you ride and we’ll get back to you right away.
Sold as a pair with installation instructions and heat-sensitive tape for monitoring brake caliper performance.
Calipers are directionally engineered for maximum performance, notice the red arrow in the lower right of the picture.
Sintered metal pads are included with every Brembo caliper.
We can also supply master cylinders (such as the Brembo RCS), aftermarket brake lines and aftermarket brake rotors to completely transform the braking performance of your motorcycle.
