1 - 4 of 4 Posts
interested in knowing if the front wheel and rotors from an 2006 will be able to fit a 2003....
I heard the 2005 rotors are bigger and hence will not fit, but I'm not sure if its all the rotors on models above 2005 that have larger rotors or was it just 2005 and then they went back to the smaller type.
www.1seven1.com
'05-'07 front (probably '08, but I've never tried) are a clean swap.
Older than '05 doesn't fit the later bikes, so that probably means the later wheels don't fit the older bikes.
Rear wheels swap '03-'07. The spare wheels for my '06 are from an '05.
-D
Discussion Starter #3
the wheel are a clean swap.... '03 -'07
but what about the front rotors?
would I be able to take front wheel including rotors and mount directly to 2003 without modifications.... or would I need to be 2003 rotors???
Custom User Title
rotors are differenct sizes on the 05 and up.
all wheels from 03 to 08 fit onto each other. but the rotors do not. you will need 2003/04 rotors.
1 - 4 of 4 Posts
