1 - 8 of 8 Posts
My R6 eats my money.
Have a TD this Saturday. Figured some of you might know the answer to this question right away.
Can I pull one or more fuses to cut power to my headlights, all signals, and plate light? Thanks much...
Discussion Starter #3
Unplug them. The headlights are the little blue connectors below the dust cap. Super easy to get to.
The brake is the only other thing you need to disconect. Just look under the rear seat for the connector
Thanks. Yea, I know I can take the headlights out. Was just curious if there was a fuse I could get to easily that would solve this issue. Guess I'll just pull everything if I don't get a response on this.
yes, you can pull the fuses. there are 2 separate fuses. 1 for the headlight. 1 for the rear. the fuse box is labeled. i believe 1 is headlight and 1 is signals
Discussion Starter #6
You da man! :toocool: Happen to know where this fuse box is located??
1 - 8 of 8 Posts
