1 - 20 of 31 Posts
Hey Guys,
I have my first sport bike and only have about 50 miles seat time on my 06 R6 so I'm still learning. I was playing with the throttle and opening it up wide in 1st and for some reason I thought the front wheel would come up but it doesn't. I even tried chopping the throttle around 10k rpm and 12k rpm and it pulled up the front suspension but no wheel lift.
Am I just to much of a noob on the bike or do the R6s not lift the front wheel on throttle alone?
Thanks guys
Malcolm
oh that wheel will come up just depends if you want it to, i can get it up with no clutch in 1st 2nd 3rd, 1st and 2nd sitting, but thats with a little gearing, when i had stock gearing i could get it up 1st no problem 2nd with a little umph
· i rule my r6
just clutch it up and call it a day doing power ups is harder and u have no control on how fast it will come up just make sure you don't 12 it cause a lot of people that 12 there bikes drop it on the side and wreck the bike so be careful
Oh ok so I just need some more practice. I only weight 130 lbs so I doubt it's my weight haha
So what's common on sprockets? -1 up front? I read some posts where people do -1 up front and +2 in the back. Wow that seems extreme doesn't it?
I should probably get more seat time before I start playing with sprockets.
I'm to scared to clutch it just yet. A little more time on the bike to get comfortable with it. Oh and I should add that I don't believe I've had it beyond 12k rpm yet so maybe at higher rpms the wheel will come up.
I'm not trying to do crazy wheelies yet, I was just surprised the front wheel didn't come up.
Oh and good call on the gas tank. I do have a full tank, maybe when it's almost gone and lighter up front we'll see a difference.
· i rule my r6
dont be afraid to clutch it up but get more riding under your belt first and its 1 down in the front makes a huge diffrents i went 1 down and 2 up but i got my bike set for drag its one of the fast 600 in michigan right now
oh and try doing a stand up its easer cause u dont feel like your falling
Yeah I wheelie the YZ all the time and my old dual sport KLX used to get wheelied a lot. It's just the whole new bike and first time ever on a sport bike nervous type thing. I'm sure I'll get over it with a bit more riding. And yes I will clutch it up sooner than later to get the feel of it so if it ever does happen on accident or what ever while riding I know what to expect and how to handle it.
· My R6 eats Chuck Norris
My 02 surprised me a bit when i bought it, this is before i knew that the prev. owner was a moto mechanic and "played" with it.
Mine will bring the front up in 1 2 or 3, throttle only (i don't even have to be full on) and I weigh 180+.
My biggest problem is not control, as a little twist either way brings me up or down. My issue is that if I get far enough forward to avoid lifting, I get a nasty wheel spin out of the rear, and it seems to like to drift to the right as this is happening... I usually opt for lifting the front :D
· Atom Smasher
My first track day on the R6 I had the front comming up every time I smashed the throttle into the stops.
· I whore my R6
no way, the r6 cant wheelie, in fact, it cant even go above 60, and it will lose to every cbr, gsxr, and zx6r, and tricycle, sorry...this is common sense man, lol
· R-Sex
any damn bike out there will do a wheelie in 1st gear by just throttling it. jus play around with it some more. preload the suspension a little, you'll see. it gets easier each time :werd
ROFL..... now there's a flamethrower! :lmao
Discussion Starter · #18 ·
It's ok :) was an honest question. Having never ridden a sport bike and then rapping this bike up to 12k in 1st I just expected the front wheel to come up. Guess I need to play some more and figure it out.
1 - 20 of 31 Posts
