1 - 5 of 5 Posts
Well guys, I wandering if ya'll could help. I got the front brakes off my 02r6, but after that I can't get the main bolt that goes all the way through to loosen. After the brakes, what is the next thing that I do. I would appreciate any help.
Team: Teletubby racing
with my 04' i use a 32mm socket to get the nut off the axle, and tap the axle till it slides right threw
2007 R6
You need to loosen the two fork bolts on both sides first. I assume you haven't done that yet and then just get a cloth and cover the end of a socket wrench but it on the axle bolt and GENTLY tap it through.
2007 R6
The "but" it on the axle... should be (put)
1 - 5 of 5 Posts
